Sequence Generator Pro 4.1.0.730 (BETA) is Released for Test
Sequence Generator Pro 4.1.0.730 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.1.0.730
Additions
  • A target can now elect on start to perform a rotation without verification (blind rotation).
  • SGPro will now log memory stats if it fails from an Out of Memory error.
Changes
  • Alter the title bar color slightly so icons are more visible.
  • Copying events from one target to another is substantially faster.
  • Deleting a targets event is substantially faster.
  • Minor layout changes to splash screen
  • The ASTAP focus metrics provider will now wait up to 30 seconds to complete (up from 5).
  • Windows have slightly lighter border color so they are more visible when floating atop mostly black images.
Fixes
  • Addressed several laggy aspects of sequence load.
  • Addressed several UI issue that could leak Windows resources when SGPro was loading or opening a sequence.
  • Attempting to center manually with incompatible sync settings will produce the proper error message (to the user)
  • Corrected an issue where a failure in the centering routine might emit a message indicating that there was a failure with the auto guider.
  • Fixed an issue that cause a sequence to fail if a target first slews and then rotates a camera, but has no plate solver selected.
  • Fixed an issue where deleting a target event could cause an Out of Memory exception.
  • Larger event numbers (up to 99) will no longer have their parent circle visually clipped by the event table.
  • The Image History Detail window is re-sizable again.
