Sequence Generator Pro 4.1.0.739 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.1.0.739
Additions
- Added better logging around GNS startup.
- SGPro can now manually set the mechanical angle of the rotator.
- SGPro now displays both the current sky and mechanical angles of the rotator.
Changes
- A moderate refactoring of the Flats Calibration Wizard. Equipment used during calibration is no longer dependent on sequence gear and will no longer affect the current sequence.
- An error loading a profile now shows a message warning about potential outcomes if it is saved in that partially loaded state.
- Sequence and profile switches are now completely portable and can be opened and edited on machines without switch drivers installed (without fear of resetting and overwriting all of your switch states). Same feature coming to other gear soon (not likely in 4.1)
- SGPro will automatically check for updates every day during beta (was previously every week)
- SGPro will no longer attempt to connect to sequence switch devices if a valid device cache is present.
- The equipment profile manager is no longer a modal window.
- The issue reporting tool now makes it clearer that the log explorer has sections that can be expanded to reveal more logs.
Fixes
- Fixed an issue where SGPro may crash if a switch used during the sequence had be renamed or removed.
- Fixed an issue where SGPro may fail to check for updates on start due to a security issue.
- Fixed an issue where some equipment profiles may have 0 as the desired number of flats frames for flat events.
- Fixed an issue where the auto focus darks folder could not be set.
- Fixed an issue where the equipment profile manager might not show brand new profiles in the list.
