Sequence Generator Pro 4.1.0.745 (BETA) is Released for Test
Sequence Generator Pro 4.1.0.745 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.1.0.745
Additions
  • Finally… themed scrollbars for most things in SGPro.
Changes
  • Control borders in the Black Theme are more defined (esp the radio control)
  • Slight adjustment for theme colors in the notification center
  • Small optimizations for event table scrolling
Fixes
  • Corrected an issue where the labels for event rotation were using the wrong icons.
  • Fixed a display issue where the event progress bar would not resize properly based on visibility of the event table scroll bar.
  • Fixed an issue that may cause SGPro to crash when the camera disconnects.
  • Fixed an issue where a sequence may fail to open depending on the structure of the previously open sequence.
  • Fixed an issue where a TEC failure during cooldown could cause SGPro to crash.
  • Fixed an issue where target settings may not display the corresponding altitude for a start or end time.
  • Fixed an issue where the settings changes that require a restart would not apply of the restart was delayed.
  • Fixed an issue where the target list would not grow in size when the height of the sequencer windows was changed.
  • Fixed several formatting issues for sequence start failure errors.
  • Small loading optimizations.
