Sequence Generator Pro 4.1.0.746 (BETA) is Released for Test
Sequence Generator Pro 4.1.0.746 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.1.0.746
Changes
  • Better separation between target name and radial progress bars in the sequence module.
  • Now using an alternate method to query the rotator for its capabilities (new method is guaranteed to not cause the rotator to move during connect).
  • The default color for new UI elements is now black. This should reduce the chance that a slow loading UI component might flash bright white before it is themed.
  • Themed the scroll bars for the main image display. I think thats all of them, let us know if you see any others.
Fixes
  • Disabled numeric controls are now properly themed.
  • Fixed a timing issue that might cause the UI to deadlock during sequence background load.
  • Fixed an issue that might cause another targets events to flash briefly before returning to the events of the selected target.
  • Fixed an issue where the SGPro might fail to emergency abort some equipment activities.
  • Fixed several issues where a failure to install an external dependency like a star catalog would provide an unhelpful error.
  • Misc small UI and theme tweaks
