Sequence Generator Pro 4.1.0.752 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.1.0.752
Additions
- Status for sequence background load is now reflected in the sequence module.
Changes
- Restore progress bar refresh rate to normal speed.
- Sequence background load status has been completely moved out of the main status bar so it does not conflict with other activities like frame and focus.
Fixes
- As intended, the bayer pattern dropdown menu now contains the most common choices, but any pattern can be uses (typed out manually).
- Fixed an issue where some tooltips that should never be hidden could be turned off with the SGPro option to hide tooltips.
