Sequence Generator Pro 4.1.0.761 (BETA) is Released for Test
Sequence Generator Pro 4.1.0.761 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.1.0.761
Changes
  • Charting of image history data has been relegated to a background task to make sequence loading faster.
  • Only the three most recent sequence files will be opened automatically when the sequence is loaded.
  • Sequence with a very large number of sequences are now prompted to remove unused sequence files.
Fixes
  • Fixed a rare issue where auto save, with perfectly bad timing, may cause a newly opened sequence to be clobbered with the data from the previously opened sequence.
  • Fixed an issue that cause sequence saves to fail for very large sequences.
  • Fixed an issue that may have caused a long delay in opening a sequence if sequences were opened in close proximity to one another.
  • Fixed an issue where the limiter for image history was broken and SGPro would allow very large histories to be saved (would cause very slow load times).
  • Fixed an issue where the target loading progress popup might not hide if the sequencer window is closed.
  • Fixed an issue where very clicking on a new target very quickly after startup might do nothing.
  • Possible fix for a rare condition in which the event loading progress will not hide when done.
  • Sequences that have a very large number of history items are now automatically culled on load.
