Sequence Generator Pro 4.1.0.789 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.1.0.789
Changes
- Add temporary logging to the Native Eagle Switch Device.
- Sequence start checks for the blind solver will no longer prevent the sequence from starting (if the underlying HTTP request hangs).
Fixes
- Fixed an issue where changing between cameras that use Binning and ISO would show an erroneous error message.
- Fixed an issue where the Flats Calibration Wizard would get lost if the last attempt was a zero length exposure that was below the target ADU.
- Fixed several of the non-modal window right-click to reset position functionality.
