Sequence Generator Pro 4.1.0.827 is Released for General Use
Sequence Generator Pro 4.1.0.827 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.1.0.827
Additions
  • Better logging for Flats Calibration Wizard in order to better facilitate support requests for failed runs.
Changes
  • For Connect All Equipment, any switch devices required by the sequence will be connected first.
Fixes
  • Fixed an edge case in the flats calibration wizard where the run might deflect off of a zero length exposure incorrectly and cause the run to fail.
  • Fixed an issue that might cause the Eagle to fail to connect if custom switch labels are used.
  • Fixed some Eagle switch mappings to support Eagle 4
  • More attempts to address SBIG CFW8 compatibility issues.
