Sequence Generator Pro 4.1.0.850 is Released for General Use
Sequence Generator Pro 4.1.0.850 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.1.0.850
Additions
  • Added a new option to reset device cache files from the UI (will be rebuilt at next connect).
  • Additional switch device logging for troubleshooting.
Fixes
  • A failure to set the state for sequence start will now properly prompt to stop or continue sequence.
  • Fixed an error where the ASCOM focuser might not be cleaned up correctly in certain conditions.
  • Fixed an issue where a clockwise manual rotator movement would contain a counter-clockwise arrow.
  • Fixed an issue where bad cache values for available switch devices might cause an equipment profile to not load.
  • Fixed an issue where some list view controls would clip the right edge when the scroll bar appeared.
  • Fixed formatting and layout on the on the Center Scope dialog attempt list
  • SMTP notification channels no longer require a username and password to function.
