Sequence Generator Pro 4.1.0.882 is Released for General Use
Sequence Generator Pro 4.1.0.882 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.1.0.882
Additions
  • For targets that require transit data calculations (altitude locks), the target name might contain a small dot out in front. If the dot is red, there was an error making some required calculation, if the dot is not red, it is queued for calculation soon. No dot indicates that the calculation was successful (or not needed).
Fixes
  • Fixed an issue where altitude locked start and end times would not update after the background loader finished the required time calculations.
  • Fixed an issue where re-opening a sequence that had already been open would not properly start the sequence background load.
