Sequence Generator Pro 4.2.0.1052 is Released for General Use
Sequence Generator Pro 4.2.0.1052 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.2.0.1052
Changes
  • The flat box shutter now uses a toggle switch instead of radio buttons.
  • The flat box will now kill the brightness before it opens.
Fixes
  • Fixed an issue where a misbehaving flat box driver might cause SGPro to become unresponsive after a shutter actuation.
  • Switches need to be set prior to connecting equipment
  • Target Tooltip should be disabled when tool tips are disabled.
