Sequence Generator Pro 4.2.0.1075 is Released for General Use
Sequence Generator Pro 4.2.0.1075 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.2.0.1075
Changes
  • Flat Box status updates for the UI are now throttled.
  • Flat Boxes now produce significantly less logs.
Fixes
  • Attempt at fixing a timing issue that may cause Alnitak(-like) flat boxes to seemingly randomly turn the lights off at the start of a flat frame. Unsure if this is the only issue (hard to reproduce)
