Sequence Generator Pro 4.2.0.849 (BETA) is Released for Test
Sequence Generator Pro 4.2.0.849 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.2.0.849
Additions
  • Drag and Drop Reordering for Targets
  • Drag and Drop Reordering for Events
  • New Image History Auto Focus trigger
  • Per-event image history added to Event Options
  • Added a new option to reset device cache files from the UI (will be rebuilt at next connect).
  • Additional debug information for switches.
Changes
  • The FITS header window is now resizable.
  • The Image Grader window is now resizable
Fixes
  • A failure to set the state for sequence start will now properly prompt to stop or continue sequence.
  • Attempt to fix an issue where an image might not size to fit on load.
  • Better target loading behavior for fast clickers
  • Fixed a condition in which user abort of a Sequence Recovery may not work properly.
  • Fixed an error where the ASCOM focuser might not be cleaned up correctly in certain conditions.
  • Fixed an issue where a clockwise manual rotator movement would contain a counter-clockwise arrow.
  • Fixed an issue where bad cache values for available switch devices might cause an equipment profile to not load.
  • Fixed an issue where some list view controls would clip the right edge when the scroll bar appeared.
  • Fixed an issue where the Equipment Profile Manager would not allow gain and offset value of Not Set to be used.
  • Fixed formatting and layout on the on the Center Scope dialog attempt list
