Sequence Generator Pro 4.3.0.1080 (BETA) is Released for Test
Sequence Generator Pro 4.3.0.1080 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.3.0.1080
Changes
  • log less about calculating AutoFlats start and end time
Fixes
  • Fix an issue where data used in the least squares regression might not be properly filtered.
  • Fixed an issue where AutoFlats would attempt a least squares regression with less than three values.
  • Fixed an issue where the least squares regression in AutoFlats may produce a very negative value and cause failure.
