Sequence Generator Pro 4.3.0.1139 (BETA) is Released for Test
Sequence Generator Pro 4.3.0.1139 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.3.0.1139
Additions
  • Added a bunch of logging for pre-AutoFlats events to track down dawn flats hang.
  • Added a watchdog mechanism to prevent a potential hang during the meridian flip if something internal to Windows fails.
  • At sequence start SGPro will conditionally return the focuser to the position of the last known start (but only if the time of day of the current start is within plus / minus 1.5 hrs and the calendar day is plus / minus 15 days). This only applies to the ‘Focus before Sequence Start’ trigger.
Changes
  • Remove flat box trace logging (issue seems to be fixed)
  • Successful sequence recovery messages are now always sent to external notifications regardless of selected messaging filters.
Fixes
  • Fixed a condition that may cause the sequence to hang if a frame is started with just barely enough time to complete before the target end time.
  • Fixed an issue where AutoFlats might ignore safe / unsafe conditions when it is run as a part of a parent sequence.
  • Fixed an issue where sequence image history HFR might be way off for frames captured directly before an auto focus run.
  • Fixed an issue where SGPro may indicate that it needs to be restarted when any setting in the Options Dialog is changed.
  • Fixed an issue where specific sequence notifications that are designed to be sent regardless of user status level filters were not being sent.
