Sequence Generator Pro 4.3.0.1213 (BETA) is Released for Test
Sequence Generator Pro 4.3.0.1213 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.3.0.1213
Additions
  • Added the beta implementation of the SkyTools 4 target importer.
  • Adding the definitely not bug-free horizon import tool to the beta
Changes
  • Adding some non-functional trace logging for debug
  • Adding support for PlateSolve 3
  • Allowing Horizon import from file
  • Temporarily re-enabled the old Flats Wizard until AutoFlats can cover all use cases.
Fixes
  • Fix an AutoFlats UI issue where attempting to override a flat events reference event would not stick.
  • Fixed an issue where an equipment profile may fail to load if the profile does not specify an auto guider.
  • Fixed an issue where the Run Sequence button would still read Resume Sequence when a sequence completed.
