Sequence Generator Pro 4.4.0.1333 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.4.0.1333
Additions
- Camera readout mode is also now written to FITS header READMODE (was previously just in READOUTM)
Changes
- A request to force Auto Focus at the next frame can now be canceled by clicking the same button again.
- Added additional debug logging to trace a state that will not allow a sequence to start even after reset.
- When SGPro is unable to set switch state for sequence start, the resultant dialog will now close on a timer with the default answer of YES.
Fixes
- A manual Auto Focus run can no longer be requested during end of sequence actions or camera warmup.
- Fixed an issue where a telescope sync option that should have been removed (target offset) was still present for selection (but did nothing).
- Fixed an issue where after-sequence AutoFlats may not prompt the user to optionally run when the user has paused the sequence manually.
- Fixed an issue where attempting to abort from an unsafe restart period would do nothing.
- Fixed an issue where AutoFlats may not open if a previous flat event exists whose parent has been removed.
- Fixed an issue where flat events that straddle the min exposure limit may not carry a brightness value (and brightness regression would fail).
- Fixed an issue where some mounts may refuse to position themselves for AutoFlats if they were previously parked while awaiting start.
- Fixed an issue where the AutoFlats transition from exposure length to brightness would cause a crash.
- Fixed an issue where the regression fallback method may calculate a predicted brightness in the wrong direction.
- If a request to force focus on the next frame is never executed because the sequence is aborted, the request will be forcibly canceled.
- The initial Auto Focus run will no longer be skipped if the first frame in the sequence is non-light.
