Sequence Generator Pro 4.4.1.1350 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.4.1.1350
Additions
- Added an option to the Help menu to directly open the File Explorer folder that SGPro uses to store profiles.
- Added new options to the Sequence menu that allow for settings the sequence start or end switch state manually. Useful for testing or manual startups.
- Switches can now define custom equipment initialization delays prior to starting a sequence.
- Switches in the same groupings can now define delays that will enforce a specific ordering for setting state. This is applicable to both start and end states.
- Update SGPro documentation to reflect Chain Solver and new plate solving options.
Changes
- Better logging for ASCOM CFW showing if the CFW supports offsets
- Changed the text displayed for Read Only switches to Read Only from Not Available
Fixes
- Addressed an issue where deactivation could fail locally.
- Fixed a bug that may sometimes cause ASCOM filter offsets to not import into SGPro.
- Fixed a minor display issue for the Pan and Zoom module.
- Fixed an issue where closing the flat box shutter after mount park (on sequence end) would not always await mount park completion.
- Fixed an issue where end of sequence switch state may have been set before long running end of sequence actions are finished.
- Fixed an issue where the equipment profile may have stored illegal state values
- Fixed several bugs related to orphaned switches
- Fixed several bugs that were mostly specific to the ASCOM DigitalLoggers switch driver
- Fixed several issues where the switch cache may have stored illegal values.
- Making STRSZ1X1 FITs header uppercase.
- Removed a command to restart the autoguider that may cause sequence failure for guider setups that use the main telescope.
