Sequence Generator Pro 4.4.1.1361 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.4.1.1361
Additions
- Added a more helpful error message for when PlateSolve3 is failing due to Windows blocking it as a suspicious app.
- Added a new sequence level option that will allow switch states to be ignored for restart on safe events (if a global sequence end time is set)
Fixes
- Fix an issue where old switch profile entries with a blank value were identified as valid orphan switches
- Fixed a condition in which the end of sequence actions may not subscribe to the mount park complete event and as a result never run end of sequence switch state.
- Fixed a minor error where child switch introspection will no longer attempt to connect to uninstalled switch devices.
- Fixed an issue where a partially uninstalled switch device may try to emit cache during sequence save and fail.
- Fixed an issue where ASCOM FlatBoxes that do not have an automatic cover would continually prompt the user to remove the flatbox for every light frame.
- Fixed an issue where restart on safe events may cause the sequence to end with the switch start state still active.
- Fixed an issue where the global sequence end time was not honored whilst awaiting start time for a target
- Fixed several tooltips that were VERY VERY wide amd would render off screen.
