Sequence Generator Pro 4.5.0.1482 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.5.0.1482
Changes
- ASCOM switch devices are now more resilient and can, in some cases, self repair when corrupted.
- List box group headers are now better themed according to your choice.
- Now, in the event of a failure when loading sequence switch state, it can no longer corrupt other parts of the sequence as a result.
Fixes
- Fixed an issue that may prevent switch devices with similar names from working properly.
- Fixed an issue that would cause SGPro to crash if an attempt was made to edit the state of a read only switch.
- Fixed an issue that would cause switch device group headers to flicker badly whenever the mouse was moved over the control.
- Fixed an issue where a switch device may fail to connect after it was interrogated during sequence load.
- Fixed an issue where ASCOM 7 caused the switch simulator to stop working in SGPro.
- Fixed an issue where switch device control buttons would sometimes not respond to clicks.
- Fixed an issue where the switch state dropbox control did not sully cover the switch state text.
