Sequence Generator Pro 4.5.0.1631 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.5.0.1631
Additions
- Added a new tab to the Control Panel that presents all sequence shutdown options together in a single view.
Changes
- When connecting the Safety Monitor as a result of starting a sequence, SGPro will no longer shut the sequence down if the initial signal is UNSAFE, but rather just proceed immediately to restart on SAFE.
Fixes
- Fixed a couple minor textual display errors in the Planning Assistant.
- Fixed all in-app links to ASTAP.
- Fixed an Equipment Profile Manager issue where a profile might only partially load due to a migration issue from SGPro 4.4 profiles.
- Fixed an issue in the native ASTAP plate solver that might fail to properly convert the solved target angle to equatorial PA.
- Fixed an issue where new targets would not inherit horizon options from the current User Profile.
- Fixed an issue where the Equipment Profile Manager switch value were not editable because clicking them showed the switch properties instead.
- Fixed an issue where the Target Planning Assistant might not be able to open again after closing until reopening the Target Settings window.
- Fixed an issue where the use of a custom horizon in the Planning Assistant would not stick.
- Fixed an issue where where enabling start analysis via the image context menu would disable itself on the next fame.
- Fixed the download link to PlateSolve3
