Sequence Generator Pro 4.5.0.1663 is Released for General Use
Sequence Generator Pro 4.5.0.1663 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.5.0.1663
Additions
  • Added extensive debug tracing to the ASTAP plate solver.
Changes
  • Added a new mosaic canvas provider that should be superior to the current DSS2 backup provider.
  • Recognition that the primary mosaic canvas provider is not available is now 17 times faster (and will move on to the next provider MUCH faster).
  • SGPro will no longer apply specified between frame delays to the first sub in a new target.
Fixes
  • Fixed a timing (race) issue that could cause an observatory shutter to close or equipment to disconnect but not both.
  • Fixed an initial connection UI reporting issue for FlatBox devices with shutters.
  • Fixed an issue that would allow the target centering routine to proceed unimpeded by a failure to sync the telescope to the current position. This would cause the centering attempt to fail downstream and present an error that is more difficult to trroubleshoot.
  • Fixed an issue where a plate solve might be considered as suspiciously bad in certain areas of the sky (math is hard)
  • Fixed an issue where an UNSAFE state shutdown might be aborted by a guide start lost event in close proximity to the UNSAFE event.
  • Fixed an issue where recent changes to an equipment profile that was then applied to the current sequence would apply values assigned to the old equipment profile.
  • Fixed an issue where starting Auto Focus manually might fail if an auto guider was not selected.
  • Fixed an issue where the Apply Profile to Sequence function would not apply recent changes to equipment profiles to the sequence.
  • Fixed an issue where the Crosshairs option in Frame and Focus was no longer honored.
  • Fixed several UI state issues for dome slaving.
  • Fixed some numerical parsing issues that may cause SGPro to classify valid ASTAP solves as failures.
