Sequence Generator Pro 4.6.0.1660 (BETA) is Released for Test
Sequence Generator Pro 4.6.0.1660 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.6.0.1660
Additions
  • Added a new ASTAP native setting that forces ASTAP to use the scale hint provided by SGPro instead of attempting to automatically determine image scale.
  • Added a new tab to the Control Panel that presents all sequence shutdown options together in a single view.
  • Added better diagnostic information for ASTAP solve failures.
  • Added extensive debug tracing to the ASTAP plate solver.
  • Added some additional diagnostic information when PS3 fails to load.
  • Sequences can now run a user scripts on sequence start.
  • The Mosaic and Framing Wizard now remembers last used angles and and panel overlap settings.
Changes
  • Changed the way in which SGPro load the PlateSolve3 solver.
  • Changed the way SGPro interfaces with PlateSolve3 such that it should be more resilient with Windows security issues.
  • Exposure length for flat frames now supports up to 4 decimal places.
  • Much better messaging when observatory shutter fails to close because the mount failed to park.
  • Sequences with time gaps between targets will now stop mount tracking until the next target is ready to start.
  • SGPro will no longer apply specified between frame delays to the first sub in a new target.
  • The ASTAP solver no longer defaults to using the auto scale hint.
  • When connecting the Safety Monitor as a result of starting a sequence, SGPro will no longer shut the sequence down if the initial signal is UNSAFE, but rather just proceed immediately to restart on SAFE.
Fixes
  • A partial fix for a memory leak caused by large sequences that will ultimately crash SGPro.
  • DSLR cameras that save both RAW and FITS images no longer create duplicative historical entries.
  • Empty, disabled, or unavailable solver selections get an early configuration message.
  • Fixed a couple minor textual display errors in the Planning Assistant.
  • Fixed a potential image history deadlock seen more with very large camera images.
  • Fixed a timing (race) issue that could cause an observatory shutter to close or equipment to disconnect but not both.
  • Fixed all in-app links to ASTAP.
  • Fixed an Equipment Profile Manager issue where a profile might only partially load due to a migration issue from SGPro 4.4 profiles.
  • Fixed an image angle normalization issue for some ASTAP Native images.
  • Fixed an initial connection UI reporting issue for FlatBox devices with shutters.
  • Fixed an issue in the native ASTAP plate solver that might fail to properly convert the solved target angle to equatorial PA.
  • Fixed an issue that would allow the target centering routine to proceed unimpeded by a failure to sync the telescope to the current position. This would cause the centering attempt to fail downstream and present an error that is more difficult to trroubleshoot.
  • Fixed an issue where a plate solve might be considered as suspiciously bad in certain areas of the sky (math is hard)
  • Fixed an issue where an UNSAFE state shutdown might be aborted by a guide start lost event in close proximity to the UNSAFE event.
  • Fixed an issue where applying a profile to an existing sequence would overwrite the target angle settings.
  • Fixed an issue where AutoFlats would fail if focus hints were available for use but no focuser was available.
  • Fixed an issue where MFW sequences that auto rotate to target angles now properly select the sky value instead of mechanical.
  • Fixed an issue where minimum auto focus fitment would appear to not save in equipment profiles.
  • Fixed an issue where new targets would not inherit horizon options from the current User Profile.
  • Fixed an issue where newer AstroBin targets would fail to import into SGPro.
  • Fixed an issue where recent changes to an equipment profile that was then applied to the current sequence would apply values assigned to the old equipment profile.
  • Fixed an issue where some buttons might look disabled until a mouse over event occurred.
  • Fixed an issue where some equipment profiles may not load in SGPro 4.5
  • Fixed an issue where starting Auto Focus manually might fail if an auto guider was not selected.
  • Fixed an issue where the Apply Profile to Sequence function would not apply recent changes to equipment profiles to the sequence.
  • Fixed an issue where the crosshairs display was no longer sticky between images displayed within the same tab.
  • Fixed an issue where the Crosshairs option in Frame and Focus was no longer honored.
  • Fixed an issue where the Equipment Profile Manager switch value were not editable because clicking them showed the switch properties instead.
  • Fixed an issue where the Target Planning Assistant might not be able to open again after closing until reopening the Target Settings window.
  • Fixed an issue where the use of a custom horizon in the Planning Assistant would not stick.
  • Fixed an issue where where enabling start analysis via the image context menu would disable itself on the next fame.
  • Fixed an issue with the ASTAP native solver where solving would fail on machines using commas as decimal separators.
  • Fixed several UI state issues for dome slaving.
  • Fixed some numerical parsing issues that may cause SGPro to classify valid ASTAP solves as failures.
  • Fixed Stellarium copy and paste for locations text boxes in SGPro.
  • Fixed the download link to PlateSolve3
  • Mouse-cursor solving uses only enabled, click-capable solvers.
  • Stabilized various focuser movements in the Auto Focus routine
  • Temporarily restored AstroBin target import using public assets… until formal API access is restored.
