Sequence Generator Pro (Beta 7) 2.4.0.2660 is released for testing.
Changes:
- Adding the sequence name to the start of all notification messages
- Fixing an issue where non-FITS images could not be blind solved in target settings
- Adding additional validation around dome slaving options
- Fixing the disconnect menu item: now includes all equipment objects
- Adding connect all equipment menu item
- Adding keyboard shortcuts to connect and disconnect all equipment (Ctrl+Shift+C and Ctrl+Shift +D)
- Adding an option to the auto guider tab that will force the auto guider to recalibrate on target change
- Adding direct access to filter AF exposure times in the AF settings dialog
- Attempt to make HFR calculations for very large images much faster
- The default ISO for new sequences is now 800
- Sequencing Window and Control Panel buttons (and keyboard shortcuts) now toggle these dialogs
- Fixed a bug that would allow the camera to be manually disconnected during a sequence
