Sequence won't after updates
Upgrading for version above 2.5.1.2 cause immediate end to the image session on my setup.
Reset progress or a new sequence does not help.
Max
Any had a chance to look at this ?
Max
Not yet.
Nothing in the log really points to any problem.
Can you attach the sequence you’re attempting to run?
Is there any additional information in the error box that pops up?
I never see an error. SGP thinks the sequence is complete and shuts then down.
I have tried to reset progress , it does not help.
All sequences give the same result including ones made after upgrade. Roll back to V .12 always fixes this.
Max
Are you making the sequence off of the same profile?
Please attach a sequence, profile, or both.
I hope this helps. It was either Sequence m57 or m57-2 with G4 Moravian Camera profile.
It also happens with SBIG profile.
https://www.dropbox.com/s/53e1k1n8swzji43/m57.sgf?dl=0
I need to fix this to upgrade to a new version
You can try resetting your UI settings by running:
c:\Program Files (x86)\Sequence Generator\Sequence Generator.exe /reset
You can also try copying out all of your profiles into another area so they don’t get picked up by SGP.
Can I just copy them back after reset?
Yes, but if that causes sgp to have issues you may need to rebuild the profiles.
