I’m using a QHY163M at the moment. In the event options gain setting, would it be possible to set the gain when the camera is not actually connected? As it is now, if the camera is not connected the only options are “Not Set” and “Link Cam”.
Since I create my sequences ahead of time on a separate computer, the camera is never connected when I create the sequence. So I have to remember to change those gain values just prior to starting the sequence and I don’t always remember. I should note that I am also mixing narrowband and LRGB in the same sequence, thus the need to change the gain for different events in the same sequence. If I forget, then the wrong gain could be used for whichever filter I’m on.
