I seem to be falling backwards again on SGP and still trying to overcome a few things…sorry
for this…really.
I am usng the Framing & Mosaic Wizard tonight to (hopefully) catpure NGC7380 Wizard Nebula.
After selecting the target I get the following prompts:
CREATE > Replace or
CREATE > Append …I select Replace
Then I select: Slew to Target & Center
Other Options:
Associate working image with sequence …I check that
Next: I get a “SUCCESS”
In the Sequence window, I select Target Settings…
- What should be the options with " Center on When Target Starts" (Checked or not checked)
- What should be the options with " Slew to when target starts (Checked or unchecked)
- The Center Now Button ?
Here’s what’s confulsing me: If I’m using the Framing & Mosaic Wizard and I have the sequence created from the Wizard, do I have to worry about “touching” any of the TARGET SETTING options from within the SEQUENCE such as items 1, 2, or 3 above?
OR, after I complete the sequence from the F & M wizard, do I just then select “Run Sequence” and forget all the above?
Incidentally, I have just ordered a new laptop running Windows 7 and have retired my XP Pro machine to the recyling depot.
I am currently running everything on my other backup laptop with VISTA 32…temporarily.
