The ISO value for centering and frame & focus gets reset to the highest setting when a sequence is opened.
This is with a Nikon DSLR
What value are you saving to the sequence here? Is the camera connected or not when opening a new sequence?
ISO1600.
The camera is not connected when i open the sequence, before i connect to the camera no values show.
I believe this bug appeared at the same time that more ISO values were added in SGP
I cannot reproduce. ISO 1600 seems to save and load fine. I think it is related the the ISO cache in your sequence. Can you post that please?
Here’s the sequence.
It’s a friends setup, i help him with the technical stuff ![]()
Ok, thx. I was not able to produce that exact issue, but I was able to find an issue that, for that sequence, would not load ANY ISO values when opened. I suspect what I fixed and what you are seeing are related and I’ll marke this as fixed in SGPro GREATER THAN 3.1.0.394. We’ll reopen it if it’s not.
I can confirm that it’s fixed
