Hi all. Last night I upgraded to 3.2.0.479. Immediately, my QHY10 failed to deliver images, only providing blank shots, with a vertical line down the centre of the screen, which appears to be amp glow.
I rolled back to the previous version of SGP and problem solved. I reinstalled the new version and the same problem again. Has anyone else had this issue, and is there a solution please?
An imaging buddy using a QHY8 is seeing exactly the same thing with v3.2.0.457. Thinking there was a problem with the camera, he switched to his older SXV-H9, which is working correctly. When I helped him setup his SGP a few months ago, his QHY8 was working correctly but I don’t remember the version of SGP that was being used at that time.
I’ve been using my QHY8l on v357 up to now. Grabbed an inside shot set up on my desk. Upgraded to 479 and with everything else the same experienced the same problem. Pics attached. I’d be happy to assist here since I’m on the bench.
We may need some help identifying where the issue was introduced…for whatever reason the QHY10/11 have always been a “little bit different” compared to how their other cameras handle things.
Further to the below issue, I’ve just restarted my machine and tried to connect with my QHY10 to SGP 3.1.0.457 and now I have exactly the same problem with that version… it’s so strange - never happened before. Do you have any thoughts please?
I’ve got s similar problem although in another program using QHY native driver. I told those developers about it and after contacting QHY they found the issue that affects the older CCD models (they switched away from using winusb in the SDK, which broke support for the older models) and it will be fixed in the next SDK release. EDIT: in that program, if I install the the dll from 2/28/2020, the camera functions again. Dont know if this is the same problem
I have not used SGP yet. But it looks like it uses ascom to control the QHY cams. The program I am using uses QHY native drivers, so I don’t know if this problem is the same or not. With the native driver, QHYdll was the problem, with the ASCOM driver I just dont know, but I mentioned it in case the developers of SGP need to look into it.
Hello. I just discovered my QHY12 is experiencing the same issue. (see attached images). If I use the EZCAP software that comes with the camera (and uses windows native drivers I assume) it works fine. However with SGPRO/ASCOM it seems broken. I see the temp. workaround is to roll back - how do I do that? Thanks!
Yes, that is the way that I have got it working at the moment… to roll back to the previous SGP version. Just go to their website, download the prior version, and install it. It will install over the top of the old version. Don’t uninstall your current version before you install the new one – I did that and I lost all of my settings etc… So just install the old version and you’ll need to re-register it on their website too probably.
