I’m testing SGP 3 and I found a small problem (bug?). My capture laptop has a 13" screen and when I open the Planning Tools window, some control buttons are inaccessible as the window cannot be moved.
I wish some boxes were free floating boxes instead of being attached to other boxes, this would solve your problem Marcelof im sure.
Paul
That probably needs to be made into it’s own pop out box. Makes that form pretty long especially on “smaller” screens.
You may be able to get around it now by hitting enter to confirm.
The same thing happens when you open the pop up dialogue to set end of sequence events - the box is fixed and the button is hidden behind Windows’ task bar, if it does’t auto hide. There is no way to continue. The fix is to Esc out of the pop-up and raise the sequence window before opening the end-of-sequence pop-up. This will often pop-up the dialogue box above the task bar. This, and probably other, pop-ups really should be free floating, or set to open higher on the page/screen.
Same problem here with the planning tools window. There was a mention of a way to enter the local horizon. Is this located in the off-the-frame part of the box?
NM: I see it now. Still not exactly sure how it works, though.
Kevin
I realize this is an older post but I am having the same problem with my 13" laptop now. I haven’t yet found a solution that will allow me to see any warnings or errors that ay be posted below the main planning tool window.
