I’ve using SGP 3 for 2 years with a SBIG STXL-11002 and has been working fine until I installed NINA Sbig tracker. It is a similar driver to SGP API Guider.
I understand there could be some dll incompatibility, but the real problem is that, once NINA camera is installed, SGP API Guider get broken and there is no way to make it work again. I’ve uninstalled and reinstalled everything without success, and it has happened to me on two computers so I think it is a common issue. Is there a way to get SGP API working again without formatting everything?
I have 2 PHD2 logs that show different errors. First one is with Nina Tracker installed and it says that system cannot find the specified file.
14:00:05.020 00.033 5024 CoCreateInstance: [80070002] El sistema no puede encontrar el archivo especificado.
14:00:05.024 00.004 5024 ASCOM Camera: Could not get CLSID for camera SGP API Guider (ASCOM)
14:00:05.027 00.003 5024 Alert: Could not create ASCOM camera object. See the debug log for more information
After reinstalling SGP API Guider, error changes to:
14:03:04.432 00.024 2680 Alert: ASCOM driver problem: Connect: (ASCOM.SGP_API_Guider.Camera) Device is not connected
Both logs can be downloaded here: Dropbox - File Deleted
Thanks in advance
