TL;DR version: SGP is the only program that stops talking to my mount sometimes.
Long version: I’m running the latest (Beta) version of SGP, so I am not looking for support so much as I am reporting this issue in the hopes it can be looked at / asking what additional info you need from me? (however please note that I have had this issue occur in the prior version of SGP, I just haven’t reported it because I thought it was possibly a cable / hub issue but I replaced those).
PC: ASUS laptop running Windows 8.1 all windows updates installed (I’m likely going to bite the bullet finally and upgrade to Win10 in the near future).
Equipment list:
Mount- Orion Atlas Hypertuned, using the shoestring astro USB cable. Using EQMOD latest version and ASCOM latest version.
Main camera ZWO 1600-mmcool
Filter wheel EFW (zwo) 8 slot
Moonlight Focuser
ASI291 mini guider cam
Polemaster
The guide camera get’s plugged into the USB hub that’s part of the 1600, the filter wheel as well. Then the USB 3 from the 1600 goes into one of the two usb 3 ports on my laptop.
The other usb port from the laptop goes into a new usb 3 hub (https://smile.amazon.com/dp/B00WE65I5K/ref=cm_sw_em_r_mt_dp_U_dSFTCbJ9CQJ4K) Atolla 4 port USB 3 It’s a $10 hub because I basically end up replacing it every year or two cause of field wear. That’s connected to the laptop with a USB 3 extension cable that’s 6’ long. From the hub I have the Polemaster, the Moonlight Focuser, and the Shoestring Astro cable to the mount.
In operation I know that SGP has lost it’s connection to the mount because I will try to center on a target, so either I command a slew (the rarest occurrence), or most often I command or the sequence commands a “center on target” and the platesolve route runs. When this happens SGP will solve the initial frame, attempt to move the mount 1 to x number of times. When the mount connection get’s lost the next place solve frame will have the exact same or extremely close Number of pixels off-target counts. That is usually how I tell that this error has happened, that the center sequence window is showing me 2 or more tries to move the mount but the pixel counts did not change.
When things are working correctly SGP usually has things centered up within 3-5 moves at most.
Since I’m planning on upgrading this laptop to Win10 I’m likely just going to wipe it completely and start over, install win 10 from scratch and then download and install ASCOM and the rest since this is now my dedicated astro PC. However before I do that if there are any log files etc that would be helpful in troubleshooting please let me know and I will grab them off.
Also worth noting is that SGP is the only program that seems to have this issue, or at least the only program that I have noticed it with. I have used Stellarium with Stellarium Scope with no issues. I use PHD2 for guiding and have never had any issues with PHD2 loosing the mount connection. I have also tried the trial version of Prism with this setup and had no issues. I also occasionally use SharpCap Pro and Firecapture with this setup, they display mount position and let you slew and no issues there.
Thank you in advance!
