I just noticed that when I click on the “wrench” by the camera connect in SGP, I get the camera default settings (which are adjustable). Mine say the gain is 10 and the offset is 10. Does this override what I’ve input in the “equipment profile manager” window for gain? Also there is a “reset saved camera” button - what does that mean?
There are 3 levels of Gain/Offset for the ZWO native driver and they’re applied in the following order:
1 - Per event
2 - In the camera settings in the control panel/equipment profile
3 - Default in the camera settings.
The “Reset Saved Camera” option really only applies if you have multiple ZWO cameras connected (maybe an imager and guider). Essentially if you have 2+ ZWOs, SGP will prompt you for which one to connect and will then save this as it is likely the “normal” camera that you’d connect to SGP. If you need to change that, you click that button and it will remove the saved camera and prompt you again. If you’ve never seen this prompt it is because you only have a single ZWO camera.
