Dear all (especially developers / support, I have active subscription)
I very much like SGP. Nevertheless, I have some trouble which really impacts my imaging sessions. It happens in almost every second night that SGP crashes (application closes) or my mini-PC freezes. So: Two types of undesired events: 1. PC freezing or 2. SGP crashing, while windows stays in a workable state without showing any error or notification.
When SGP just crashes, I am not loosing valuable imaging time (clear sky nights are rare events in my regions. Winter: rain, clouds. Summer: not dark enough), it also happens that my mount goes on tracking as end of sequence steps are not initiated (as SGP is no longer running). I am a little worried that I get a pier collision or something else. These things usually happen in the second part of the night, when I go to bed and when the whole system is unattended.
I am not a PC expert. But it seems that this happens during image capture. The windows log files reflect the issue, when the SGP crashed. They show that there were issues with SGP and with the module ASICamera2_ASCOM_x64.dll . So, what does this mean? And how can this be solved?
I have made log files from three nights with issues available through the following link. In those folders, I copied win log files (only present when SGP crashed, and not, when the PC froze), SGP log files and SGP sequences.
Here, some background information on issues:
- 2022-03-23 SGP crashed (app was closed) at 1:46 am
- 2022-03-05 SGP crashed (app was closed) at 1:42 am
- 2022-03-03 SGP mini-PC completely froze, no win-log data, time: 1:55 am
It is also remarkable that these events preferentially seem to happen a relatively short time when I leave my imaging PC alone and go to bed. I usually control my mini-PC through remote desktop using “Jump”-app on my ipad. I usually close Jump and also Skysafari when I go to bed. I do not know whether this is coincidence (what I actually assume) or whether there is a relation.
I do only have two apps running on my PC during imaging. SGP and PHD2. My ZWO cams are controlled trough ASCOM. In the last imaging session, I also closed down all other stuff, such as Pegasus Astro Power Box advanced user interface. I control my mount through Sky Safari Pro (newest version) using SGP’s external control.
Here some hard- and software information:
I use an i5 mini PC with Win10 Pro, 8GB RAM, 128 GB SSD + second 500GB SSD. It’s an ACEPC CK2 (seems to have vanished from the market this year). I am using the latest SGP4 64 Bit version (the 4.0.700). The sequences likely were created on an older version of SGP (where I sometimes also had this freezing issue, but I changed equipment often and cannot make accurate statements anymore). I have ASCOM 6.5 SP. A ZWO asi2600MM and asi178 (guidecam), EAF focuser and an EFW filter wheel (7x2”). These devices are all connected (USB + power) through a Pegasus Astro Powerbox Advance. I use a CEM 70 mount with ipolar. PHD2 2.6.10. So far I used the ZWO ASCOM driver 6.5.1.13 and older versions. Today I updated to 6.5.2, which I have not tried out so far.
Cable issues are very unlikely. Two years ago I spend a lot of time finding out which cables are good, what is the maximum length, etc. Never had any download issues with images since I optimized cables two years ago. Everything is powered by a 230V AC waterproof powerline in garden where I installed two power transformers, one for the mini-PC (that one which came with the PC) and also a second 12V converter (150W) which provides 12 DC output for allastro stuff. The PC has wifi connection, and in each night I control it through remote desktop. I also have a small TFT and small keyboard for direct access at my imaging rig.
So… I have no idea what is the reason for crashing or freezing. But since this happened in three of my last 5 imaging nights, I really need to solve it. I have no ideas whether this is a software or a hardware issue. But it seems it has something to do with the ZWO-ASCOM-X64 driver. So, what could I do?
Just one last comments. I also shot dark libraries in the basement of our house. Here, I use the same mini-PC, but no mount, no guidesope and other equipment. Just the PC with the camera. While shooting a very large dark library (also for other cams), I experienced PC freezing only once so far. These issues appear to be more rare under these condition. However, I do not have a sound statictic basis (I hope that this issue will be solved prior to establishing large statistical data…).
Any comments are HIGHLY welcome. Please …. I need some help
Thank you very much
Best wishes
Jan
