Subject: Issue: SGP Not Reading Offset Value for ASI294MM Pro at Gain 200
Body:
Hi everyone,
I’m running into a frustrating issue with my ASI294MM Pro camera in Sequence Generator Pro. When I set the gain to 200 using the ASCOM driver, SGP does not seem to read or apply the offset value correctly. I’ve manually set the offset to 30 in the ASCOM driver settings before connecting the camera, but:
• SGP does not reflect the offset value anywhere in the UI.
• Filenames generated using show .
• There’s no way to confirm that the offset is actually being used during image acquisition.
I understand that the ASCOM driver for ZWO cameras might not expose the offset parameter to SGP, but this is a real limitation—especially when trying to maintain consistent calibration frames. I’d love to know:
• Is there any workaround to make SGP recognize or log the offset value?
• Are there plans to reintroduce native ZWO support in SGP, where offset was previously accessible?
• How are other ASI294MM Pro users handling this?
Any insights or suggestions would be greatly appreciated. Thanks in advance!
—Ewa
