I used SGP for the first time using my portable kit when away on my holiday through France - I’d often set off the sequence before going to sleep and let it run through as much as possible on its own (which it mostly did with only a couple of small issues).
Equipment used was:
Losmandy GM8 with Gemini 1 L4
QHY163M + CFW2-US-M + Canon 200mm f2.8L (at f3.85)
ASI120MM on a guider
I still have data left to process and to add to so I can complete images, but here’s some shots below - links to the Flickr pages give the details about each one.
Thanks for looking!
I use SGP at home, but it’s much more hands on (I have to rotate my dome every so often…) - this is the first time I’ve truly got it running by itself with no intervention for significant periods. It’s good software, I really like it.
