To be honest not sure where to post this, don’t think this is an actual SGP issue but had some issues last night as was approaching flip, some odd behaviour with SGP where it kept losing the RA/DEC and Time to flip information and then followed by PHD2 no longer sending guide commands and finally a SkyX application crash
As said, not sure where the fault lies here so posting on all relevant forums but would be grateful if you could take a look at the logs and provide any feedback.
Software versions
OS Windwos 8.1 x64
SGP 2.4.1.3
SykX 10.3.0 (Build 8805) (Paramount MX)
PHD2 v2.5.0pre2
ASCOM 6.1 SP1
TheSky Controlled Driver V 6.0.5391.19493
Log files for SGP, PHD2 and screenhsot of the TheSky Controlled Driver settings
Looking at the SGP log things start to go wrong @ 12/04/2015 01:26:15
[12/04/2015 01:26:15] [DEBUG] [CP Update Thread] Caught exception in CanPierFlipNow : No more threads can be created in the system. (Exception from HRESULT: 0x800700A4) (System.Runtime.InteropServices.COMException (0x800700A4): No more threads can be created in the system. (Exception from HRESULT: 0x800700A4)
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR(Int32 errorCode)
at System.Dynamic.ComRuntimeHelpers.CheckIfMissingTypeInfoIsExpected(Int32 hresult, Boolean throwIfMissingExpectedTypeInfo)
at System.Dynamic.ComRuntimeHelpers.GetITypeInfoFromIDispatch(IDispatch dispatch, Boolean throwIfMissingExpectedTypeInfo)
at System.Dynamic.IDispatchComObject.EnsureScanDefinedMethods()
at CallSite.Target(Closure , CallSite , ComObject , Int32 , String )
at CallSite.Target(Closure , CallSite , Object , Int32 , String )
at ASCOM.SoftwareBisque.Telescope.get_SideOfPier())
at ASCOM.DriverAccess.MemberFactory.CheckDotNetExceptions(String memberName, Exception e) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 623
at ASCOM.DriverAccess.MemberFactory.GetTargetInvocationExceptionHandler(String memberName, Exception e) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 664
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type parameterTypes, Object parms) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 231
at ASCOM.DriverAccess.Telescope.get_SideOfPier() in c:\ASCOM Build\Export\ASCOM.DriverAccess\Telescope.cs:line 895
at ai.CanPierFlipNow()
In PHD the first error is @ 01:43:15
01:43:15.871 00.010 12944 pulseguide: [80020009] Exception occurred.
01:43:15.871 00.000 12944 Error thrown from scope_ascom.cpp:586->ASCOM Scope: pulseguide command failed: (TheSkyXAdaptor.DirectGuide.1) COleException: No more threads can be created in the system.
(800700A4) SCODE: 800700a4.
01:43:15.871 00.000 12944 Error thrown from scope.cpp:626->guide failed
Then at 12/04/2015 01:54:00 the SkyX crashes, cant find any logs for the SkyX so only this from the event log.
Faulting application name: TheSkyX.exe, version: 10.3.0.8805, time stamp: 0x552340de
Faulting module name: TheSkyX.exe, version: 10.3.0.8805, time stamp: 0x552340de
Exception code: 0xc0000005
Fault offset: 0x00f72b7e
Faulting process id: 0x1730
Faulting application start time: 0x01d072ebcb1eddeb
Faulting application path: C:\Program Files (x86)\Software Bisque\TheSkyX Professional Edition\TheSkyX.exe
Faulting module path: C:\Program Files (x86)\Software Bisque\TheSkyX Professional Edition\TheSkyX.exe
Report Id: 678981e7-e0ae-11e4-82ee-f81654cd60c6
Faulting package full name:
Faulting package-relative application ID:
