Am I correct that SGP does not have its own logging capability? I am aware of PHD2’s logging and ASCOM’s Trace function. I am not asking about those. I am asking whether SGP creates a log of its own actions, steps, and statuses.
Yes SGP has great logging (almost too much). I don’t have SGP open so I can tell you where to find it. It may be under “help”. But it there.
Yes, under the help menu you can find links to the logging directory as well as the current log.
Thanks. I did just find it. I had looked in the User Manual and could not find a reference to it. I looked in the Help Menu and there it was. By the way, I also clicked on the “Help\Learning” selection and I get an HTTP:404 ERROR. Thanks again. I hope the log will help me find out why the dome is not slaving to the Telescope Simulator. I am at the bottom of the SGP learning curve (obviously).
I think I understand what happened to my dome slaving trial. I believe the telescope simulator assumes the telescope is initially at RA = 0; Dec = 0 and movements are computed from there. If that is true, then from my calculations, the dome ended up just where it should have.
I did notice that in the Log, the dome slaving parameter is Radius, not Diameter. “SlavingVals: ->Radius:” And, that the value appearing there is the one entered in the Slaving setup as “Diameter”.
I will try tomorrow to use the actual telescope, enter the correct radius value, and see how the slaving works. Hopefully, the alignment will be correct.
I think it would be helpful, if possible, to report the resulting dome azimuth in the log.
Also, why does the log say, “bSlaveObsToScope: False” when the log then reports “Attempting to auto slave the observatory…” ? That’s confusing.
