SGP not remembering settings
Hello, great software all in all but some annoying issues…I was wondering if anyone could assist me with one small question. I waste a lot of time re-ticking and clicking a bunch of boxes and settings every time I reset a sequence. For instance, I have to tell SGP where I want to save files to every time, and in framing and mosaic wizard I have to tell it not to auto rotate (I don’t have one). These are just 2 examples of may. This is plain silly and I’m sure there’s a way to get SGP to remember your last settings. I just can’t find it!
Did you try the help files? Learn about profiles and how they affect your sequences!
Kinch
To answer your specific questions:
  1. You can define your default images directory so that SGP will always save your images in whatever directory you choose. Go to Tools/Options/Default Images Directory. See below.
  2. There is no way to tell the F&M wizard to not rotate by default. You will always need to uncheck that option.
Beyond that, Kinch is right, read up on equipment profiles and how they work. Note that once you create a new sequence based on an equipment profile, that new sequence is completely independent of the profile. Changes made to either the profile or the new sequence will not affect the other.
Tools%20Options%20Default%20Images%20Directory
