Just wanted to do some testing of an issue with my camera and started a new sequence and for all the equipment selected ‘No [name of equipment]’. Only entered my camera and settings for it. Hit Run Sequence and SGP returned that a filter wheel is required for imaging. Selected Simulator for it, tried again, then it returned that a Focuser is required for imaging. I would think that if no equipment was selected, then it would not require simulators to run a sequence. Seems a bit naggy or am I missing something?
I’ve just tried it with nothing but the camera and everything else set to none. I got it to run but it’s tricky. It took nearly half an hour.
There are multiple places in the device control panel where a focuser or filter is implied and if they aren’t all disabled you get messages about the lack of hardware.
The paradigm seems to be that if an operation that requires some sort of hardware is specified then the pre start checking will fail if that hardware isn’t available, meaning selected and successfully connected. This makes sense because it protects a user from starting a sequence, going to bed, and getting up the next morning to discover that, because he’d not connected the focuser none of the images are in focus.
I think the problem is the way the UI has grown. The control panel is separated into device specific sections but some features manage the interaction between devices so it’s difficult to know where they should go.
I have also had this kind of trouble. It occurs when I am trying something out without using the whole imaging setup.
Sometimes not using the mount, sometimes not using the camera or focuser or autoguider.
I could build a new equipment setup with only the subject complement. But that takes a while to get working. It would be nice to be able to just go into the Control Panel and select something like “Ignore” for the camera or focuser, etc. Then, when something is encountered in the sequence that requires that equipment, SGP would ignore that action, or, perhaps just give a one-time reminder.
When I say it is difficult to remove a piece of equipment in the Equipment Manager, I usually select a profile similar to what I use then deselect, say the camera. But when I do that the other dependant settings are retained and I have to track them down and deselect that particular option.
I understand that this may be difficult to do properly without causing undesirable interactions, but I think the authors could do this better than I can.
Thank you for your consideration.
Fred Klein
Yeah I think even though I’ve selected No equipment, the Control Panel seems to have setting from the default profile. I’ve now created a profile with no equipment selected, that seems to work, but I need to test it a couple more times.
Correct. By selecting options that require a focus and not having a focus selected we’re in somewhat of a bind to know what to do. Did you accidentally set the focuser options or did you accidentally remove the focuser? We don’t know.
However the dialog that pops up should tell you what options are set so you can find them and remove them.
Yeah I had a profile assigned as default that contains my main imaging gear(focuser, telescope, dome, etc.). It was driving me crazy for a bit but now I know what it is it’s easy to define a ‘No Gear’ profile and use that for testing.
Thank you
