First I like to apologize for my bad English, but I have
some problems with SGP which I cannot solve myself.
When I connect my QSI583wsg camera the camera is cooling
down and the Fan is at full power. The fan allways remain on full power even if
the camera is on temp or if it warms up. FAN Option Quiet mode is not affected in the QSI driver, it is
allways full power.
I have a SharpSky focusser with temp control and ASCOM
driver. The temp control of the focusser is switched off , in ASCCOM, when I
connect the focusser in SGP. SGP can read the TEMP sensor when connecting, but
is not updating the temperature so no corrections are send to the focusser. The
Temp Compansation Trainer does not switch the TempCompEnabled option on in de
Ascom driver.
I have iOptron iEQ45 mount, SGP can connect the Mount,
but it only read the Ra,Dec,Alt and Az value, it cannot move the Mount. The
arrows are all gray and cannot be pushed.
With Starry Night Pro 6 or 7 and with POTH Hub I can move
or possition the Mount. I cannot park the Mount, this option is not availeble
in the iOptron ASCOM driver, I know. In SGP the telescope is connected with the
POTH hub.
In case off guiding, SGP only reads the PHD log file, but
cannot send any information to PHD or start or stop guiding or what ever.
Server settings are on in PHD. Maybe this is related with the issue above.
There are a lot of problems I know. Some may be related
to each other.
My biggest problem is the Temperature Compansation on the focusser and the Telescope
Connection.
Note: SGP version 2.3.13.2473, ASCOM version 6.1, PHD 2.2.1, ScopeDome
RollOffRoof 1.1.0.1 connecting ASCOM via Generic HUB or POTH HUB.
Paul
