SGP use with DSLR
I recently acquired a Nikon d750. BackyardNikon definitely will work for image capture but before I go down that path I wanted to know if SGP can be used for DSLR image capture since I have used it for years with my QSI camera.
Thank you for your input.
Clear skies!
Phillip
If it works with BY Nikon then SGPro can use it too. Both applications use the same underlying libraries to talk to Nikon cameras.
Thank you Ken!
I have a Nikon D750 and it works well with SGP. One thing that I do is remove the SD cards.
Roger
Hi Roger,
Thank you for the tip on removing the SD card.
Do you post your images on AstroBin?
If you do, I would like view them.
Thank you!
I started doing astrophotography with a Nikon D750. I then moved on to using a ZWO ASI2600 one-shot color camera. Many of those are on ASTROBIN.
Roger Menard
