Is there any information for SGPro 4 beta on the support for dual SGP instances?
I now have a setup with 2 cameras/telescopes on same mount and can set up 2 instances, but i am unable to get them to work properly (i’m just guessing on how to make them work now: one has the telescope control and the other is just imaging)
I am running two separate instances, and two separate sequences.
“main” version has telescope control, handles dithering, etc.
“sub” version has just sequence information (no goto, dither, etc.)
i’ll take the hit on uncoordinated dither for now
What i’ve seen:
I start up two separate instances with two separate sequences
when I start the second sequence, it appears to try and start a target from the first sequence, even though that target is not part of the second sequence
if I abort “main” sequence, “second” sequence reports waiting for next target, even though that target isn’t on the list of active targets in “second”
and I’m happy to do additional testing or do something more controlled
Still no “real” reply on this question. What I mean by that is true multi-instance, multi-camera support with coordinated dithering. That is what nearly everyone means when they ask for multi-camera, not just the ability to run multiple cameras in multiple instances. The latter works but by it’s nature will mess up at least some of the frames from one or more of the cameras. Not what we need for our precious sky time and for a dual camera mode where the entire idea is to produce more data!
Is this ever going to happen? When? Many of us would love to have even a test version.
