SGPro crashes when copying events to targets
Have a sequence which includes 48 targets (variable stars) and trying to copy a series of events to each target from the first in the sequence. Works up to a certain point then SG Pro closes without warning. Have included the full log in the drop box link Dropbox - File Deleted
The approach is to have a complete list and select the stars on a particular night which are visible and need an imaging run. The rest will not be used.
Looks like there are some limits to number of events in a sequence? If so what are they? and can this be managed in some other way?
Managing the target list in a sequence slows down dramatically the more targets you add and also adds dramatically to the time it takes to open a sequence. Hopefully at some point this can be made much faster, one of a large number of feature enhancements that have been requested. In the meantime, I try to keep my target count under 10. Why not organize your targets so that only targets visible in the current time frame are included. You could have a list for each month, as an example.
I think the key here is the total number of events (=targets x events) not necessarily the number of targets. I am trying a series of events per star which covers a set of three filters at different exposures and gains - these are variable stars and the magnitude range can be large. Trying to automate the evening without lots of sequences as the targets will not only vary by visibility but by cadence - some imaged every session, others every 10 days or 20 etc. determined by what was achieved in the last imaging run. Not too bothered about loading time as I want to do that only once - tick the boxes on the sequence list (the exact entries I can get that from another piece of software) and run sequence - come back a couple of hours later - job done. The perfect world !
