Good day!
Sorry if this was already …
I want to perform light frames with a shift between them.
Please tell me how to correctly indicate this in the sequence.
I use CEM 60 and PHD 2.
I am not sure what you mean by this. A “shift between them” is what?
I think he meant dithering in between frames. Yes you can easily do that but Dmitry didn’t provide enough information about his equipment like scope (brand, aperture size, focal ratio), camera (brand and model), etc.
You must enable the server in PHD2 (under “Tools”) in order for SGP to communicate with PHD2 to get dithering to work properly. You can setup dithering information in SGP under “Auto Guide” like “Extreme Dither”, “Settle at < X.X pixels” and “for XX seconds”.
Peter
Thanks for the answer.
My CEM60 mount, C11EDGE telescope with focal length corrector up to 1480mm (F5,1). My main camera is ASI1600mmc. Off-axis guide ASI178mm with 2x2 binning.
