I don’t know if that’s a bug, but yesterday I ran into a failed slew. This happens at the start of the next sequence if you check the “Stop tracking when sequence completes” checkbox in the telescope preferences. If I leave that checkbox unchecked, it works fine, but for security reasons I prefer that the mount stop tracking at the end of its sequences.
I’m sure Chris will chime in, but I guess you could run a simple VB script in the event options to connect to the mount, check/turn on tracking and then disconnect.
I finally figured out the solution last night. For AP mounts among the setup options in Setup Telescope, there is a checkbox that says “Auto-enable tracking…”.
