SnapCap flats Box SGP3
SGP has the Snapcaps in the drop down and I have the snap caps, but SGP will not adjust the brightness. OR, it will not adjust the brightness of the panel that I set in SGP for each filter. Doesn’t even bother to turn on the led. What it does constantly want to do, is open my snapcap, everytime the flats fail. Even if I try to do it manually, one filter at a time, as soon as I click start on the wizard, it shuts the led off and starts imaging.
Did you set the brightness in this window…
…and save in the profile that you are using.
I set the brightness in “other” under flats setting. I will try it here.
That worked putting it into that window.
Thank You!
Thanks for reporting back - that will help others too.
