Hey everyone! I have been using SGP for some time now, successfully plate solving (PS2) and last night I had it fail for the first time since I initially set it up on my laptop. The only software difference between the last time I plate solved was the latest update. No hardware changes. I took a picture in frame and focus, then right clicked to plate solve and it worked within seconds. When I tried to sync and solve, even blind solve, it took minutes and eventually failed. This is from home where my laptop has wifi. Something that I thought of today that might have been the problem was how gemini was set up. I started the night CWD, quick start and input all my info, and then slewed for focus. I had to adjust my DEC worm so I turned off gemini. Turning back on I believe I clicked warm restart. The hand controller said it didn’t have GPS so I think my coordinates got lost? But I just proceeded to manually put my target in FOV and imaged. Next clear night I’ll go out and see if having to restart in CWD is my problem and making sure gemini has my coordinates.
So basically does gemini need to be set up correctly for PS2 to correctly solve and sync? I didn’t think it needs to be.
