I’m trying a code a small web app to pull all the latest near earth asteroid discoveries that need confirming and dynamically produce a list of targets I can import into SGP.
I’ve got the format scrape and format done (Col A=target, L=RA, M=Dec -> total P cols tab delimited) but I get the error in SGP 3 when trying import “Object Reference not set to an instance of an object.”
Does anyone have an example starry nights target file I can view and test to make sure my .TXT matches what it expects?
… currently :
TARGET RA DEC
P10GEyV 8.6938 +16.6171
P10GDoa 10.1412 +12.6693
P10GDo9 10.3687 +13.1162
P10GDoc 10.1753 +14.2055
etc … though have been trying different coordinate formats too to no avail so far.
Yeh I used your post and one other from cloudy nights as the basis for what I did… thanks! I can’t see that what I did is any different so not sure why I’m getting the error. Have you made the jump to SGP 3.0 Steve? Do you have a txt file (even with a single target) that you could share as a test?
Thank you!! Confirmed that your file works with SGP 3 just fine. That will help me pin down my error, I didn’t realise that all columns needed labels so perhaps it’s that. Thanks again!
For anyone who needs the format in future it’s like this (Columns A -> T … the tabs don’t line up nicely on the forum but each column has a label … and I’m not sure the columns after P matter but there are 2 blank columns Q & R before the 2 labelled columns at the end)
Name Kind Mag Size Alt Az Constellation Rise Transit Set Database RA DEC Illumination Semi-major Distance dec ra dec dec
A106qxc 9.7204 +7.4620
P10GEyV 8.8175 +15.8299
P10GDoa 10.1331 +12.8484
P10GDo9 10.3591 +12.9605
P10GDoc 10.1677 +14.3724
P10GDnS 10.2881 +5.6561
P10GAtt 13.0273 +1.9240
P10GzIh 14.1382 -25.9285
P10GxwH 9.1354 +21.3928
P10GxwK 9.3976 +17.5565
P10GxwE 9.2858 +25.0784
P10GxwC 9.4786 +23.2671
P10Gxwz 9.5462 +21.5351
P10Gxwx 9.7917 +22.5061
P10Gxvi 9.6716 +16.5327
P10Gxqs 14.6499 +12.0939
P10Gxqp 8.2552 +17.0401
I also do asteroid astrometry and have a need to load lists of targets with coordinates. I was using a process
that created files in the above format which worked flawlessly with the previous version, but upgrading to
3.0.3.140 results in a “Success! x of x targets were imported” message but only the target name is loaded.
Also, the import fails to propagate the import options for centering and slewing. Any ideas as to what has changed? Any help is appreciated.
I had to insert two new columns after the RA and DEC columns for v140 to import successfully. The two new columns are RA (J2000) and DEC (J2000). Here is a sample:
