STL11000 / SGP Connection problem
Hi, I has two cameras connected with SGP with one being the ZWO 2600 MM and the other is a SBIG STL11000 CCD camera. I do not have any problems connecting the ZWO Camera. When I come to connect the SBIG CCD, I get the following error:
[Main Thread][NONE] SBIG Error while opening driver: COMMAND_ERR
What can I do to fix this problem? The error appears both on the normal version and the Beta. I have been using an old version successfully of SGP before I subscribed for the latest 4.4 version.
Below please find an excerpt of the log:
26:51.494][DEBUG][Unknown][NONE] ASCOM Switch Device: ASCOM.OmniSim.Switch Connected set to False…
[10/10/25 13:26:52.573][DEBUG][Main Thread][NONE] EndBackgroundLoad: await background worker termination…
[10/10/25 13:26:52.573][DEBUG][Main Thread][NONE] EndBackgroundLoad: background worker termination end
[10/10/25 13:26:56.967][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:27:07.053][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:27:17.134][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:27:19.922][DEBUG][Main Thread][NONE] Connecting camera in main thread…
[10/10/25 13:27:19.927][DEBUG][Main Thread][NONE] Connecting SBIG camera…
[10/10/25 13:27:19.929][DEBUG][Main Thread][NONE] Error SafeSBIGUnivDrvCommand: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
[10/10/25 13:27:27.231][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:27:37.314][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:27:47.388][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:27:57.465][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:28:06.251][DEBUG][Main Thread][NONE] SBIG Error while opening driver: COMMAND_ERR
[10/10/25 13:28:06.251][DEBUG][Main Thread][NONE] Disconnecting SBIG camera…
[10/10/25 13:28:06.253][DEBUG][Main Thread][NONE] Error SafeSBIGUnivDrvCommand: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
[10/10/25 13:28:06.253][DEBUG][Main Thread][NONE] SBIG Error while closing device
[10/10/25 13:28:06.255][DEBUG][Main Thread][NONE] Error SafeSBIGUnivDrvCommand: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
[10/10/25 13:28:06.255][DEBUG][Main Thread][NONE] SBIG Error while closing driver
[10/10/25 13:28:06.258][DEBUG][Main Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:28:07.542][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:28:17.622][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/10/25 13:28:27.695][DEBUG][CP Update Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
Regards and Thanks,
Winston
Has this machine ever connected to the STL before now? Is it a new machine or a fresh install of SGPro? Are you using 64-bit SGPro? If so, did you install the 64-bit (legacy) SBIG drivers? This here seems like an incompatible driver mismatch to me (32 / 64 bit)
